LWFW and FMIC quick questions
^ that has absolutely nothing to do with my problem. I have a problem because I have a 2.5" (smallest dianeter you can get) chunk of aluminum with hot air running through it restricting air flow to my rad. Ill also add that it has been ~85-95 degrees here everyday, an yes the rad fan is on and the aux fan cuts on when I get to the next tick then cuts off.
as for the lwfw causing chatter, either put in a heavier flywheel or deal with chatter. theres no much you can do
Ok as far as my cooling issue, my rad fan works, thermostat seems to work fine (replace ~6 months), waterpump was replaced recently, heater works fine do circulation is the issue. Is the smaller fan behind the rad suppose to be on all the time or just with ac?
