Lug pattern help searched
5x112 - 5 bolts located on a circle with diameter of 112mm. Meaning that the center of each bolt is 56mm from the center of the wheel. GOOGLE was invented for a reason.
4 Lug Pattern Measure from the center of the first lug to the center of the third lug in the pattern.
5 Lug Pattern Measure from the back of the first lug to the center of the third lug in the pattern.
6 Lug Pattern Measure from the center of the first lug to the center of the fourth lug in the pattern.
The Russian ^^^ this is good to know
sorry for the miss info, for 5 holes: the radius R = D/(2*sin(36)) where D == 5xD
but the point is that the second number determines the radius of the circle on which the center of the bolts lie
you can buy adapters to make those lug patterns fit. a guy over on vortex has some corvette sawblades on his car and he is running adapters. just a thought.
