Low whinning sound and RPM Bounce Issues
Hi Guys,
Need some advise.
I have this low whinning sound that is coming when moving off in first gear (5 speed) and also feel the shift **** pulsating. This only happens in first gear and not in the rest (including reverse).
My RPM is also bouncing around a little (between 650-750rpm) and I have already cleaned the throttle body and MAF but that didn't help.
Question is, is my transmission on its way out? How much would it cost to fix that? Any one can help?
Thank You
Need some advise.
Thank You
RE: Low whinning sound and RPM Bounce Issues
Pretty much that is it. A mech I talked to said it could be the timing belt (tensioner) put on too 'tight'? Seems unlikely as it has already been 15k miles since i was put in.
I don't think it is a vaccum leak as the mech I took it too spray 'something' on a few hoses to check for leaks and cannot find any.
A co-worker told me today that the earlier A4 (96-98) are pretty noisy (low whinning noise perpetually) in the engine bay. Anyone can confirm this?
ORIGINAL: fritz
is your ac on? could be the fan
The issue here is I don't want to start throwing $$ into it without a certainity it will fix the issue.
