Low coolant buzzer going on and off, not leaking.
My low coolant buzzer and warning light keeps going off i'd say every 10 minutes depending if i'm going up or down hills. The coolant is not leaking and there is plenty of coolant.
Is this just a loose wire or a bad sensor? The damn buzzer is annoying. It would be fine if it always reads low coolant but it keeps switching back and forth.
czwalga...how did you resolve this issue with the coolant warning light? Did you clean the sensor, replace the coolant tank, or something else? Mine goes off if I'm going downhill or if I've parked it downhill then goes away for a while. '02 A6 3.0 Quattro
Christ almighty, thread digger, and in the wrong section.....Replace the tank, the sensor in those tanks go bad after a decade.
Maybe I'm wrong, but I assume the old posts are still available to view for a reason. Which is worse: "digging" to find an answer or asking a question that's already been posted by others? Also assumed that coolant issues would be similar between A4's & A6's or B5's & C5's, etc. so when I went thread digging I didn't specify what section to dig in. Finally, I asked my question because if czwalga was able to spend a few minutes and $0 to fix it, I'd probably give that a shot, although what might take you 15 minutes would probably take me several hours because I'm no audi tech.
I did ask Christ Almighty about this first but got impatient so I came here to audiforums...the next best thing
Bryceaudi
07-31-2007 04:42 AM
