loud engine sound
Take the serpentine belt off and run the engine. If noise stops, one or more of the accessories is/are bad. Otherwise, spring for a $10 engine stethoscope and probe around till you locate the noise source. Hopefully it is not an internal problem.
Removing the drive belt and running the engine is a good way to eliminate failing accessories as a culprit, so definitely try Pete's suggestion. It sounds like a failing timing chain tensioner, but it could also be a failing pulley.
This. And if it is, don't drive it. That one is so bad you might be close to losing your cam chain completely. Then it's bye bye motor.
I bought an 00 Passat that had a bad motor. Took off the heads and this is that the cam tensioner looked like. The guide on the top is fine, the one on the bottom is pretty much gone.
Here's what was left of it:
Invisible
10-17-2013 03:47 PM
DaredevilPJ
B7 Models
11-08-2012 10:21 AM
