Loss of Turbo and Engine Cutout @ 4000 RPM
Baseline:
I have a 2000 A4/Avant 1.8T manual with zero upgrades except for the APR Stage 1 ECU programming. I've had the APR programming for about 4 years now.
Problem:
About 2-weeks ago, I had a CEL and a noticeable loss of power. OBD P0102 error came up so I tried to clean the Mass Airflow with no luck and then replaced it last week. After replacing the Mass Airflow the CEL went out, but I still had a noticeable loss of power and I cannot even feel/hear the turbo engage. In addition, if I accelerate in any gear, I will get an immediate loss of power (almost like de-fueling) when the car crosses over 4000 RPM.
After 3-days the CEL came on again. Today, had the car scanned and I have P0411. Removed the airbox, checked all hoses as well as the hard-plastic hoses going to/from the secondary air pump. Hooked everything back up, reset CEL and the light is off, but still no power. There's no smoke coming from the engine /exhaust and there's no sounds coming from the turbo so I don't think that the turbo is gone, but it's clearly not working.
It's almost like the car is stuck in valet mode - to boot, the CEL programming for the APR chip (engaged via the cruise control SET button) doesn't respond but the cruse control does work when driving. Do I have to do some "magical" ECU reset?
It's like I'm in hell driving a Ford Fiesta or something...
Anyone have any suggestions?
Problem:
Update: Disconnected ECU this past Sunday and re-checked vaccum lines. Thinks appear in order on the vac side.
Diverter Valve
Nope, never replaced that, so I was suspecting that it may need to be changed so I'll look into that next.
Boost Guage
No Boost guage installed, so I don't really have a read on what is/isn't being produced by the turbo, but I've driven this car for enough time that I can tell when it's sort of sluggish and a downright dog - it's a dog at this point.
RPM
When the car crosses 4,000 RPM in any gear, it cuts-out "bucks" and doesn't lose power gradually.
Thanks to the three of you for follow-ups. I'll get a DV ordered and go from there.
Diverter Valve
Boost Guage
RPM
I haven't had starting, idling or fuel economy issues - I'm still averaging 30-31mpg on my daily commute to work (mostly freeway of course), so I'm not thinking that it's a spark issue and I don't believe the plugs are going to affect the turbo working/not-working.
As for the CEL, it doesn't flash, just comes on steady.
Should have a new DV (710N) this coming weekend - I'll replace that as well as a vac line, test again and post an update.
Let us know what you find with the DV.
Loss of Turbo - Update
Well, I've finally received some of my mail-order parts, so here's an update;
Replaced the Diverter valve today along with the vacuum hose running from the DV as well as the spark plugs. I still have *exactly* the same problem.... The car starts, idles and runs great - I have a noticable loss of power (can't hear turbo spooling) and the enging cuts out right as the RPM reaches 4000 in any gear.
I don't have anything but guesses at this point.
Here's what I've done so far;
1. Replaced MAF.
2. Replaced Plugs
3. Replaced DV with 710N
4. Replaced vacuum hose from DV (it was looking nasty)
What else could this problem be caused from ?:
* Coil Packs?
* ECU??
* Turbo is blown?
Does anyone have an APR Stage 1 chip in a B5 A4? I have this chip installed and the program settings (set to change chip modes via cruise control button) don't seem to be able to be set.
-Perplexed.
1. Replaced MAF.
2. Replaced Plugs
* Coil Packs?
* ECU??
* Turbo is blown?
-Perplexed.
