Loose Parking Break
Loose Parking Break
I've been searching around, can't find anything. I practically pull the parking brake through the sunroof to get the car to stay. Can I adjust the cable tension from inside the car? Please let me know what you guys think, I figured this would be a really easy job. Thanks
Yes. You have to adjust the cable at each one of the back brakes. Just take the wheels off that tighten the cable adjuster nut. Be sure to check to see that you have a good amount of brake pad left, and this isn't just a sign that it's time to replace the pads.
even if your rear pads were gone or if they were brand new, the handle should still travel the same distance because the ebrakes are self-adjusting. the cable itself might have stretched over time and there is an adjustment for that, but the breaks themselves auto-adjust for pad wear.
