Looking for Shop Or HELP!!! My Brain is turning into soup!!!
Does anyone know of a reliable shop in Connecticut Danbury area or close to it? I have a misfire on cylinder 1 and 6 I've changed my MAS sensor my Coolant temp sensor and its also saying my Air temp sensor is bad. I have the sensor and I bought a new bracket but the old one was just hanging and I don't know were the bracket blots on to. Not to mention I have a leak in my Power steering, it looks like to be a hose but it could be that cooler thing in the front of the car. any help would be appreciated.
This is the Vag results
Address 01 -------------------------------------------------------
Controller: 4D0 907 551 AH
Component: 2.8L V6/5V MOTR HS D01
Coding: 06201
Shop #: WSC 06313
9 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16685 - Cylinder 1 Misfire Detected
P0301 - 35-00 - -
16690 - Cylinder 6 Misfire Detected
P0306 - 35-00 - -
P0300 - 35-10 - - - Intermittent
P0301 - 35-10 - - - Intermittent
P0306 - 35-10 - - - Intermittent
17953 - Throttle Valve Controller: Malfunction
P1545 - 35-10 - - - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
17834 - EVAP Purge Valve (N80): Open Circuit
P1426 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 M
Component: ABS/EDS 5.3 QUATTRO D31
Coding: 0273004134
Shop #: BB 24302
1 Fault Found:
00285 - ABS Wheel Speed Sensor: Front Right (G45)
30-00 - Open or Short to B+
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 D
Component: A4 KLIMAVOLLAUTOMAT_D75
Coding: 04162
Shop #: WSC 06313
4 Faults Found:
00787 - Temperature Sensor in Fresh Air intake duct (G89)
30-10 - Open or Short to B+ - Intermittent
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
01206 - Signal for Duration of Ignition: OFF
27-10 - Implausible Signal - Intermittent
01582 - Signal for Coolant Temperature
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 919 930 L
Component: B5-KOMBIINSTR. VDO D03
Coding: 06262
Shop #: WSC 00000
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
Address 35 -------------------------------------------------------
Controller: 8L0 862 257 N
Component: CV-Pump D05
Coding: 16172
Shop #: WSC 06313
2 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06313
No fault code found.
Address 56 -------------------------------------------------------
Controller: 4B0 035 186
Component: Radio D01
Coding: 00117
Shop #: WSC 06313
Coding: 06201
Shop #: WSC 06313
9 Faults Found:
P0300 - 35-00 - -
P0301 - 35-00 - -
P0306 - 35-00 - -
Coding: 0273004134
Shop #: BB 24302
1 Fault Found:
Coding: 04162
Shop #: WSC 06313
4 Faults Found:
Coding: 06262
Shop #: WSC 00000
1 Fault Found:
Coding: 16172
Shop #: WSC 06313
2 Faults Found:
35-00 - -
35-00 - -
Coding: 00101
Shop #: WSC 06313
Coding: 00117
Shop #: WSC 06313
Agreed. When I read his post, I skipped over the random alarm and sensor codes. I'm simply concerned about the misfires.
I had the codes read about 2 weeks ago. I have the car for a few months and did the Timing belt and changes the Spark plugs and wires. the car did have a blown head gasket and I replaced the head gasket on both sides. about the time I replaces the timing Belt, wires, plugs and Head gasket I also replaces the Coil pack (this is the 2.8 30v engine so it has the 1 multiple coils in the front) the car ran great up until the end of August when i started to have these problems out of the blue.
Pull the plugs and look in the cylinders for possible traces of coolant washing through them (they would look very clean inside). Inspect the plugs of the misfiring cylinders and compare them to the others. Also, inspect the coil pack connections. If they are loose or the rubber gasket is missing or deformed, they will never make good contact.
Thank you all for your input, today out of curiosity I swapped the old coil pack with the new one that I had installed and the problem went away. Seems like the new coil pack went bad. Gonna have to call and get it exchanged. But how bad is that? That new coil pack isn't even 3 months old....grrrr
