???lisen to the radio with car off???
Hey if some one can give me a hand that would be amazing.
I got have a 99 a4 i wana have my radio on when my car is not runing but when ever i put the key in the on position my lights turn on.
Is there any way to have the radio on with out the lights beaing on???
I tried pulling the e brack up and i have a AFT MRK deck in the car.
thanx
thanx
like him^^^ i can just hit the power button on my stock radio and it works however i believe you will not be able to use that function on your aftermarket radio (regardless of whether it existed in your stock radio or not). the wiring harness used to hook up the aftermarket radio uses two wires for power. a constant twelve volt for radio memory and an ignition twelve volt which gives power to the radio only when the ignition is in te on position. i believe stock harness has another wire for a different power source which is able to be activated with the radio power button and the aftermarket wiring harness does not include this wire.
amiddle104
06-23-2014 06:15 AM
Marine702
01-27-2013 07:10 PM
Maxxx
01-07-2010 07:14 PM
BOBB98.5A4QT
06-01-2008 02:10 PM
