Limp mode disabled
RE: Limp mode disabled
Is it a Transmission problem? Is the transmission display flashing or is definately misfiring? Ignition coils are a common problem and not that expensive to fix. The transmission on the other hand is very costly. Do you know what is throwing it into limp mode??
Are you getting a misfiring CEL on Cylinder 2?
What is the Mechanic telling you that needs to be replaced? Is he an Audi Certified Mechanic?
Do you know What CEL codes it is giving?
When you say Limp Mode, to me that means that the computer modules are not connecting and it's making your car go into a safe mode to prevent further damage until you can get it to the shop.
Now if it was the transmission with a flashing display, there is a way to get it out of Limp mode and a way to reset the drive cycle ( which is a temporary fix ) ...but as far as misfiring, that is something that is only going to get worse. I would Change out the ignition Coil on atleast Cylinder 2, unless you are getting a different CEL code.
Everyone hates those high and unexpected repair costs, but if you own an Audi....you should plan on about spending about $3,000 a year in maintance. The car is only as good as it has been maintained.
I suspect you are not the 1st owner of the car and it may not have been maintained properly and you are catching the blunt of that. As far as your Mechanic goes......If they are an Audi mechanic.....he should know based on the CELs what is wrong and how to reset the codes and a possible temporary solution for you....If not, get a new mechanic, or a New car!
ORIGINAL: luke30
Crunk:
I have no signs of a transmission problem and I have tested all the usual suspects for a missfire (coil packs, injectors, ICM, plugs, ect)
Crunk:
i just dont think your mechanic knows as much as you think he does. did he physically remove the cams? if he did why not swap them out? it wouldn't have cost much more. and how does he know cyl 2 is messed up? compression check?
ORIGINAL: chaos92287
tested how?
ORIGINAL: luke30
Crunk:
Crunk:
When someting goes wrong with my car, My Mechanic explains everything to me, and has a great level of confidence in what is wrong and what it will take to fix it. Ask questions! test him on his knowledge. I won't let just Joe Blow work on my Audi ....... you shouldn't either! make sure he is ASI certified. Get a second opinion, or Hell, atleast...Go to your local parts store and plug it up and get the CEL codes and look it up ! Why is it that you know so little about what is wrong with your car....especially after having a mechanic look at?????
#18
Well i will try and get a 2nd opinion. I do trust this mechanic, I really doubt that he is an audi certified mechanic however. I have had the codes read and all I got was a missfire in cylinder 2 (although it was just a generic scan...not vagcom or anything). Dealership is a 4 hour drive!
The missfire is deffinatley not coil packs (swapped them out, and disconnected), same for plugs, new ICM.
He did do a compession test and it was low in cylinder 2 but not way too low.
fzfrank
09-19-2012 10:08 PM
