lifting the a4
Old 09-17-2008 | 06:03 AM
pbc_18's Avatar
Default lifting the a4
I'm a snowboarder at heart and the a4 goes through alot but still pretty low i was wondering if anyone now or has lifted there a4 and made it look decent? I'm not looking for a redicous lift maybe an inch or two ?
Old 09-17-2008 | 08:07 AM
mainer0311's Avatar
I've heard you can go with a6 springs and struts, but I haven't seen it first hand.
Old 09-17-2008 | 09:33 AM
CAB509's Avatar
6th Gear
wow, I'm a skiier and not by any means in deep snow that often with my Audi, but I've heard that no one has had a problem with a stock ride height Audi and getting stuck in snow.
What springs are you on currently??
I think a lift would make the a4 look like **** IMO
Old 09-17-2008 | 10:19 AM
airguard350's Avatar
Tech Guru
If you got bigger tires a mild lift like your describing shouldn't look too bad. I was thinking of doing that too because the bottom of my Audi scrapes on so much **** around where I live it ain't funny. It'll scrape if a speed hump is a little too high, it's ridiculous.
Old 09-17-2008 | 11:47 AM
McGovs2.7TB5's Avatar
Seems pointless IMO. 2" of lift is alot more than it sounds I would think it would be pretty hard to not have it look ridiculous.
Old 09-17-2008 | 12:28 PM
brettofburke's Avatar
its not pointless at all.... run a basic rally setup...
Do this, get tein's rally suspension... i think its like 1500, call them and tell them you want the true rally setup. You can run 18's and it will look like a stock ride height. The rally setup has stiff *** springs too, so you can fly over speed bumps and small children and the like.
...OR....
you could not drive through deep snow
Collapsable shovel.... 20$ @ the Home Depot
Old 09-17-2008 | 12:45 PM
onepoint8tee's Avatar
A perfect excuse to get coil overs!
Old 09-17-2008 | 12:48 PM
The only storm where my A4 had to stay parked was 3+ feet and it was buried up the side views. If i spend $1500 on a suspension that mf-er better be dragging its ***. to the op, where do you live? Are you gonna spend a bunch of time and money to have a lifted a4 and only go riding once a year? **** you could probably take the $1500 you were about to spend on a rally suspension and buy an old 4runner. Tune that bitch up and go ridin with out ever worrying about scraping.
Old 09-17-2008 | 01:11 PM
euro_2nr's Avatar
^^^ true dat. Late 80's 4-runners are the ****!!! The body will give out a lot quicker than the drivetrain ever will.
And I have gotten stuck in snow a few times due to snow packing under my car and putting it up on a pedestal. But I doubt the lift will solve your problems. You'll most likely tip over.
Old 09-17-2008 | 02:20 PM
ouzo 2's Avatar
from 1-10 i rate the lift idea a 2
