Leifer and My Intercooler Build Pictures
So Leifer and I installed his intercooler yesterdayand I snapped some pictures during the install. Just thought I would share them. I don't have any of the finished project (because it was late, cold, dark, and we were tired. LOL) Maybe Leifer can add some pictures of the finished project. Enjoy!
Josh
Josh
RE: Leifer and My Intercooler Build Pictures
God front mounts are sooo sexy. If only i could have one...
----Well i could seen it on a Neon(huge ricer put the front mount on, one end had a weld cap on it, the other was just in to the intake hahahhaha--
looks good, my .02, would have put the power steering cooler below the intercooler.
drill a hole in the middle of the bracket (green in pic)and put the bolt (red in pic) to hold it in place.
[IMG]local://upfiles/15922/9B0F34730087464EA1126E12D07B3D41.jpg[/IMG]
that little U shaped cooler, im not sure what its for, but its right in front of the radiator, i see that u bent it all the way up at some point, what did you end up doing with it?? i left mine between the IC and the radiator, should i have moved it?? does it heatsoak?
That cooler (U shaped one) is the power steering cooler. It works well up there. It gets cold air the whole time and as long as the clamps on the bottom of it are tight it won't leak or anything like that.
Yeah Leifer, where are the finished pics????
Josh
Josh
why are there couplers here
and here (the one on the left)
if you used the outlet hose and tb hose you should just run the piping right into them, not use a coupler.
Brian, that first pic = a 90* bends sits in there, but it's not in the pic. And that second one has a coupler because we ran a 90* to a straightpipe which we cut, because the 90* bend wasn't long enough to hit the turbo outlet.
Finished pics of it go up tomorrow, I've just been really busy trying to tidy it up.
