knocking noise coming from engine
Old 05-23-2010 | 11:33 PM
whtturboa4's Avatar
Default knocking noise coming from engine
hey i have a knocking noise on start up and when the engine is at opperating temp. and the noise is coming fromthe back of the motor. i have an 01 1.8t. if anyone has any advise for me i would really like hearing from you thank you.
Old 05-24-2010 | 01:06 AM
bradtyler02's Avatar
Scan for codes and post them... you're more likely to get some good advise that way.
Also, not to insult your intelligence, but check your oil.
Old 05-24-2010 | 02:46 PM
dragonrage's Avatar
Could be the cam chain tensioner. Could be many things, though.
Old 05-24-2010 | 09:54 PM
Pjbrof's Avatar
could be a lifter, have you tried thicker oil?
Old 05-27-2010 | 06:44 PM
jokeabus's Avatar
Probably the cam chain tensioner. Mine just went up the other day.
Old 05-27-2010 | 08:12 PM
chocalotstarfish's Avatar
Super Moderator
I have a constant tick/knock in my motor...
Old 05-27-2010 | 11:52 PM
kayakman13's Avatar
Use a stethoscope to pinpoint the sound's location. I had a knocking everyone (mechanics included) swore was rod knock. I poked around with the scope and found it to be a loose power steering pulley.
Old 08-06-2010 | 12:10 PM
whtturboa4's Avatar
well I have been poking around with sethoscope and found the knocking coming from the rear of the motor like where the cam chain is at. I have pulled codes and I'm getting a code for an advanced cam and intake air circute to low. I have also tried thicker oil but nothing seems too make the knock quiter or any good results.
Old 08-06-2010 | 12:44 PM
onepoint8tee's Avatar
Have Fun!
All VW's have slightly noisy lifters. There is a big difference between a little vw knock/tap and a bad cam chain tensioner. If your oil pressure was low enough to keep oil from getting to the top then you'd likely have a oil pressure light.. You could check your oil pressure first to be sure, though.
Old 08-15-2010 | 10:31 PM
whtturboa4's Avatar
ok i have checked my oil pressure and i got 40-60 psi. so im getting good oil pressure. but the only thing is that the knocking noise happening when i first start my car when its cold and it happenes when my car is at operating temp. so im thinking its the cam chain tensioner.
