kkk turbo?
Old 11-05-2008, 07:29 PM
mr(cool)kid's Avatar
Default kkk turbo?
so i have a 98 a4 1.8t .. i went to my local salvage yard just to look at there inventory of turbos.. so i went to there audi/vw section lookin for a good k04 .. they didnt have one but they have 2 k03's and this one turbo that caught my eye.. its stamped kkk and has a t3 flange square 4 bolt exaust side. its water and oil cooled and has no shaft play at all and turbine spins freely . looks a little bigger than a k04 .. the guy says its from an older audi but doesnt know. it has no internal wastegate so it was externaly gated .. he only wants $100 for it. i know theres no specs to go by but do you think it would be a good one to use? any help would be greatly apreciated
Old 11-05-2008, 07:39 PM
somebody5788's Avatar
Well a quick search makes it sound like its off a 2.2l Audi 5000. To me unless its 100% bolt in its not worth it because of all of the custom work you would have to do for a turbo they may or may not be more then a k04 or something.
Edit further search makes it almost seem like the current turbo's may somehow be related to those ones.
Old 11-05-2008, 07:42 PM
Mike-2ptzero's Avatar
Did the flange have a round inlet in the center?
Old 11-05-2008, 07:46 PM
other than a different turbo mani and a custom test pipe theres not much to do right? i mean the tuning and fuel.. but for about 240-260 whp do you think this would be good or just go with the k04?
Old 11-05-2008, 07:51 PM
no it was a little bit smaller oval and the flange was completly rectangle
Old 11-05-2008, 08:13 PM
Might have been a K16 which looks about the same size as a T28, the picture above is a K26.
Old 11-05-2008, 10:13 PM
so would it be a good turbo to run for daily use and decent power
Old 11-05-2008, 10:25 PM
cincyTT's Avatar
I'm make believe
No, there is no manifold, dp, or tuning for it. It would cost just as much to run that turbo for $100 as it would to run a real turbo kit.
Old 11-06-2008, 01:48 AM
EpicWin's Avatar
If it was on an earlier Audi, and was externally gated, it sounds like it came off a 5 cyl, and looked like it's the one in the pic above. So I'll bet it's a K-26, which is an OK turbo on a (much larger displacement than 1.8L) Porsche. We would usually take a K-26 and put a K27 compressor section on it in 944's and 911's. Then they could make some good power. In either case, this is not what you are looking for, move along.
Mike, I believe the K16 is internally gated. They are on all 993tt's at least.
Old 11-06-2008, 11:58 AM
k cool thx guys.. il just go with a k04 or somethin
Quick Reply: kkk turbo?
