Keyless Entry Problems
Old 05-08-2008 | 08:25 PM
well0327's Avatar
Default Keyless Entry Problems
Ok, so I can program my keyless remote, however it only stays programmed for a couple hours. After a few hours I cant use my remote unless I re-program it. Any ideas on what to do?
Old 05-08-2008 | 09:15 PM
mr.cAp's Avatar
Default RE: Keyless Entry Problems
did you try replacing your battery,
Old 05-08-2008 | 09:28 PM
ControlFreak's Avatar
1st. Replace battery in remote
2nd. disconnect car battery and touch + and - leads together. It will reset the comp. I had this problem on my wifes passnot and that fixed it.
Old 05-08-2008 | 09:40 PM
well0327's Avatar
yes, I replaced the battery in the remote. I will try to reset the comp by disconnecting the battery and see if that does the trick. Thanks! ill let you know what i find out...
Old 05-09-2008 | 12:26 AM
01AudiA4's Avatar
Make sure you have the Radio code when you disconect the bat.
Old 05-09-2008 | 02:07 PM
well0327's Avatar
I have an aftermarket stereo in it, so I dont need the radio code still do I?
Old 05-09-2008 | 03:31 PM
sineo's Avatar
ORIGINAL: well0327
Well, no.
Old 08-10-2008 | 02:02 AM
well0327's Avatar
Default Touched Pos and Neg battery leads
I touched pos and neg battery leads to reset the comp. It didn't do anything except reset my comp/trip meter. I programmed my remotes and they stay programmed for a couple hours, however I can only use them if I'm within a couple feet of my car. Does anyone have any suggestions? I'm thinking of going aftermarket...any suggestions for a 96 A4?
Old 08-10-2008 | 02:04 AM
well0327's Avatar
Old 08-11-2008 | 04:04 AM
david9999's Avatar
Do you have one problem or two now?
Regarding the short range, this is on all audi's and is due to the position of the antenna for the remote. Depending on the angle, it may only work from 5 feet away.
There have been several reported fixes including primarily moving the antenna wire for the remote, or extending it with more wire and then running it under the rear bumper
Quick Reply: Keyless Entry Problems
