Keegan's timeline :D
#82
DUDE!..... since i live so close to you i want to come write on your hood!! lol i really like it.
you can draw a bi-turbo set up on your hood lol.
try ebay or craigslist.. or when i get my new rims you could buy mine?? idk if you like mine though...
#83
Ethan, you BETTER be at cars and coffee next weekend!
Im going to my dads saturday night to look at those wheels. Hes out in forney, and I always pass through mesquite to see relatives, so maybe ill try to hit you up!
Add me on facebook
http://www.facebook.com/keeganxw
Driving back from college, I went into a soft limp mode I think. I just started boosting 5psi for no reason, which sucked.
Andrew, I'm looking through that list of wheels. Why are all the sexy ones 3 or more hours away? :/
Add me on facebook
#85
monday- red hood
tuesday- green hood
wednesday- pink hood
thursday- tie die hood
friday - checkered
saturday- plaid hood
sunday funday - let someone draw a picture for you
i would have too much fun with that hood
#86
I should have seen this coming.
Fishtank air tubing is NOT the best thing to run on a cooling line.
All day ive been getting weird *** vac and boost issues like extremely slow spool, max boost anywhere from 3-10psi, just weirdness in general. looked under the hood and realized that the line had semi melted, and was collapsing under vacuum. where I ran it by the turbo coolant line, it had melted just enough to stick closed, but sometimes be forced kinda open by boost or whatever. Im dumb. Tomorrow ill pick up some actual vac line
#87
Well I had this big post, but my laptop refreshed so its gone. Plus its like 1 am and I just want to knock this out.
Started debadge, got dark.
Did fog light mod. Happy as hell
Removed relay, open case, cut pins 12, 15, and 17 (numbered on relay)
Another shot with better numbers
Soldering station
Size of add on wire (way small)
Where the wire goes (soldering together pins 12, 15, and 17)
Damn im good
Location behind/above glove box, major pita to reach
I broke off the latch (on purpose, because it wouldnt fit any other way
And the end result
Next is those pesky amber corners
Soldering station
Damn im good
And the end result
#89
Soldering station
Damn im good
And the end result
Soldering station
Damn im good
And the end result
i dont have the tools to solder.
#90
If you want it, ill swap relays with you next Saturday!
