Keegan's timeline :D
Old 02-08-2011, 05:03 PM
02A6Beau's Avatar
sweet. paint it chalkboard! (kidding)
You will have to get pics once it is on. I like the way it looks in the picture but not sure how that will translate once it is on the car
  #162
Old 02-08-2011, 05:35 PM
Tourbo24's Avatar
you know that the inlet on that thing is a little too big? your gona need some adapters or re-do the whole pipe
  #163
Old 02-09-2011, 12:57 AM
Msnickbroderick's Avatar
Actual WIZARD
Need to stop posting from class corrected link
  #164
Old 02-09-2011, 11:30 PM
Actual WIZARD
P0171. Boo.
  #165
Old 02-15-2011, 11:29 PM
Actual WIZARD
Progress!
Managed to finally get the huge air bubble out of my heater core, so I have crazy hot heat now
So I was chillin replacing vac hoses, and pulled off my IC to TB pipe... SO MUCH OIL :/
Innercooler also had lots of oil in it too...
So 30 bucks at home depot later...
$7 inline air compressor filter
4 feet of 3/4 id hose
various hose clamps, pipe couplers, and 2 1/4-1/3 npt fittings
Rotated the weird rubber pipe in the back
You can see my final mounting location
Heres the issue though.
The old plastic pipe that came off the block just crumbled, and the dealer wants 70 for the part (which they don't even have in stock)
And im like F#$% that homie, im a B5 owner, ill make it work
Solution: Just cram the hose into the block!
*note. Correct tube is on order from ECS, so no flaming. It seals, so it will work for the next 4 days
Now feel free to call me retarded, because im pretty sure just running a pipe from the block to my catch can means I forgot some important component (I.E. PVC breather valve) but in reality, do I need it?
Anyway, drive the car about 80 miles, and checked the can. SUCCESSSSSS
  #166
Old 02-16-2011, 12:07 AM
Actual WIZARD
Oh and here is what a 140k pcv system thats been sludged up due to the recommended 10k oil changes (and then "repaired" by AoA) looks like:
Left side was broken off
Ew.
This was the plastic part coming off the block, obviously cracked and split down the side.
Got lean codes? CHECK THIS SYSTEM FIRST
  #167
Old 02-16-2011, 12:22 AM
DAS98A4's Avatar
Jesus
  #168
Old 02-16-2011, 12:28 AM
erasmmuss's Avatar
Who the hell belived changing the oil at 10k on a turbo is a good thing .
  #169
Old 02-16-2011, 12:41 AM
Actual WIZARD
The part that really worries me, is that theres no way this was only isolated to these 4 hoses....
  #170
Old 02-16-2011, 08:30 AM
erasmmuss's Avatar
Dude u better start checking/replacing all of them hoses ,looks like u have one of those sludgy ones
Quick Reply: Keegan's timeline :D
