K04 turbo upgrade, which software is best?
I thought the stock FPR was a 5 bar? correct me if I am wrong. And intercooler required for a K04? I am not sure i would say that you need one. It may help with heat soak some, but that turbo doesn't seem big enough to actually "need" one. I think you would be fine with the PC16 without an intercooler, unless they won't tune it. just my 2 cents.
PC 16 needs an upgraded intercooler because it pushes the K04-15 at high boost levels which means the turbo is going to be pushing out air at very high temps. High flowing exhaust should also be used.
Fact is that a upgraded intercooler should be used even on a standard K04-15 setup or even on a chipped K03. Even a chipped K03 is going to have air coming out of it that is very high in temps. The stock SMIC was really designed for low boost like the stock tune runs.
TTsteve
06-01-2007 11:48 PM
