K04 question
Old 02-19-2010, 02:44 PM
arb's Avatar
arb
arb is offline
Default K04 question
Ok so here is my situation I currently have a 99.5 A4 1.8TQ tip and I have APR 91 chip installed and I am looking a buying a K04 and Borla exhaust. I called a company close to my house (Im just north of Toronto) to ask them if I have to re-tune my car once I put the K04 on and he is telling me that APR said I don't have to? So basically my understanding is that once I bolt up my k04 my ecu will just adapt to it and I will gain more power or how does that work exactly?
Thanks,
Tyson
Old 02-19-2010, 02:49 PM
dragonrage's Avatar
You won't gain a lot of power. You can tune it to gain a little more. A K04 is only slightly better than a K03. It is not worth upgrading from K03 to K04 unless your K03 is trashed and you don't want to spend a lot on new manifolds and such for a good turbo (or for the Elim kit).
Old 02-19-2010, 02:52 PM
arb's Avatar
arb
arb is offline
yea my k03 has major shaft play and it keeps burning all my oil so I have to replace it might as well upgrade. But if i get the k04 i can just bolt it up and go nothing is going to happen
Old 02-19-2010, 02:53 PM
dragonrage's Avatar
You can. You might gain a little power over the K03 without a tune, but probably not enough to be noticeable at all. But it's more worth it than buying a replacement K03, at least.
Old 02-19-2010, 02:56 PM
arb's Avatar
arb
arb is offline
ok thats what im confused about, because the shop told me that I can't tune my car for a k04, apparently he called APR and they said if a k04 is put on and the car is already chipped you can't tune it. Is he just feeding me bs then? Because I want to gain more power as well, I think the Borla exhaust should help too
Old 02-19-2010, 02:59 PM
euro_2nr's Avatar
Yes you can run the K04 as a direct replacement. I had one laying around and threw it on my B5 and no ill-symptoms. Never noticed a big difference either and never got it reflashed either.
Old 02-19-2010, 03:02 PM
shortyxc's Avatar
GIAC does have a tune for the k04 though. Sucks that APR doesn't offer one.
arb's Avatar
arb
arb is offline
ok but my major question is can I get it re-flashed so I do notice more a of a difference? Apparently the shop I called says I cant and to just run it as is.
Old 02-19-2010, 03:04 PM
arb's Avatar
arb
arb is offline
ok cool, yea he told me GIAC did but im not buying another $700 chip so APR doesn't thats all I needed to know man. I should see a bit of gain though I hope
Old 02-19-2010, 03:14 PM
shortyxc's Avatar
Ya you will see a small gain like others have said, it just won't be as much as if it was flashed with a k04 program. Still a good route to go if you have to replace your turbo anyway. Hope that answered your questions.
Quick Reply: K04 question
