k03
Old 08-31-2010, 06:40 PM
Jc61990's Avatar
Originally Posted by Mike-2ptzero
Computer companies need to start putting breath analyzers on their products to keep the "drunk" off the web
Dont Drink and TYPE
i think cellphones more than computers.
Old 08-31-2010, 07:05 PM
Mike-2ptzero's Avatar
Time for the web browsers to add a "sobriety test" before loading up. lol
Old 08-31-2010, 07:50 PM
turbo kraut's Avatar
Tech Guru
then i would never be on here...... damnit
that is all i do when i get home from work is drink
Old 09-08-2010, 11:21 PM
1.8takeoff's Avatar
I also found a turbo off a 2004 passat is this going to fit also?
Old 09-09-2010, 02:00 AM
If it is off a Passat 1.8t then yes it will fit.
Old 09-09-2010, 10:21 PM
1.8takeoff's Avatar
will it be a lil bit better then the stock 98 k03? cuz i heard the compressor wheel is a little bit different
Old 09-10-2010, 11:27 AM
Jc61990's Avatar
here ya go
Originally Posted by cincyTT
here is the differnce
ko3 small turbo for most 2000-2001 cars
ko3s have a slightly bigger compressor, the same for a ko4-001 for 2001- on
ko4-001 or 15 has a slighly larger turbine housing than a ko3s
ko4-2x are off 225 have a larger turbine and compressor than the ko4-001
you will see some gain from ako3 to a ko3s (~10hp @ smae psi) but thats about it.
^ these turbo are all very capabable of running 20-24 daily without any problems.
^^ the compression will help spool your turbo faster (like the need it) and give more power through out the power band. Your engine was designed to run it and there are people running 300, 400, 500 plus whp with 9.5:1 compression on these engines everyday.
^^^ the spool on all of the turbos listed above are way to quick to even worry about, if you have fwd a laggier turbo is suggested. A larger turbo, even running at a low psi will allow you to get better traction and make good power, plus have room to grow.
i tried to make this own post so i hope everyone finds the response to their questions.
  #18
Old 09-10-2010, 11:30 AM
CCA4's Avatar
+1 I'll drink to that!
  #19
Old 09-10-2010, 11:42 AM
The info for the turbos is all good if you own a Transverse car, completly a waste of info if you own an A4. lol
  #20
Old 09-10-2010, 11:44 AM
aledelic42's Avatar
wanna share these k03's you're finding?
