Just insalled forge 004
Update with video/sound clip
http://www.youtube.com/watch?v=p743Bym9aD0
couldnt rev too loud had people sleeping upstairs, but sounds alright around :30
just finished installing this. i know a lot of people dont like bov on our cars but i cant resist the sound.
i was thinking this was going to be a lot louder from what ive read but its not...
IMG00421-20091006-1551.jpg?t=1254860838
IMG00423-20091006-1608.jpg?t=1254860914
from what I've read, adding a high flow drop in filter or some kind of intake setup makes them louder. And it doesn't matter what other people want/like, its your car. if you like it then thats the way it should be
hmm getting ready to get start on a custom intake setup anyways, hopefully that will help.
and it deff works, i can hear it, its just not as loud as i was thinking
The BOV releases air from the sytem and can create air/fuel ratio problems. I would consider getting a DV.
The stock airbox works fine for most setups. If you want to mess with it, a cone filter with custom heat shield is probably your best bet. There are a bunch of DIYs out there to help you.
correct me if im wrong but from what ive read thats only with 99 or older models, the map sensor in the 00 and 01 adjusts this problem after a day or two.
and yeah i was going to do a basic cone filter setup with a blinktek heatshield like this one...
im the same way man. i like my car in stock form already but you cant stop people from personalizing. on the bov thing, since he has a map sensor its not as bad, but still not good. but it does sound like he knows the risks.
MAP is not used to calculate the amount of air the engine's getting (unless in speed density mode i.e. MAFless). The MAF and IAT together are used for that. The sensor that will save his *** is his front O2 sensor adjusting the mixture. He needs to relocate his MAF if he wants to correctly use a BOV, but you're certainly right in that he doesn't HAVE to.
