Just got GIAC flashed!+++
Old 09-26-2008, 04:11 PM
ryanylva's Avatar
Default Just got GIAC flashed!+++
Finally got it done this morning and wow it is a difference. He took out my mbc though cuz he said it needs the n75 to run correctly. Weird cuz before the flash I bypassed the n75 with the mbc because of bucking problems and now its fine.
Is it normal for the flash to adapt? Wondering cuz as I was makin the one hour drive home the boost was slowly raising and it was getting more and more torque?
Also just found out that the squeaking I was having is from both rear springs being completely cracked! Any ideas for the best suspension upgrade that won't break the bank?
Old 09-26-2008, 04:14 PM
ghost6303's Avatar
bilstein sport shocks for $500-600 + your choice of springs for $~200 = your best/cheapest bet.
and yes the ECU adapts to a certain degree over the first few miles.
Old 09-26-2008, 04:19 PM
ryanylva's Avatar
Thanks...where did you order yours from? I want to get springs and shocks all around.
Old 09-26-2008, 04:28 PM
onepoint8tee's Avatar
You got a chip not a flash. 00+/DBW engines get flashed. Gotta love GIAC! The chip really doesn't adapt as much as you are adapting to it. Especially with GIAC. It's either a tamed ride or your're haling ***. Sort of takes a while to get used to the inbetween.
Old 09-26-2008, 04:33 PM
ryanylva's Avatar
No, it is a flash. They do it for the 97's now. After I talked to him about it two weeks ago I looked it up on giac's page and it's there. Also, I watched the whole process of him deleting and downloading
Old 09-26-2008, 04:38 PM
ryanylva's Avatar
Oh, I was also told that the temp. gauge is not going up as it should(thermostat) which will affect the performance. Also, told them timing belt is prob original so they looked and belt and tensioner are original. So, I now have an expensive laundry list for 'er.
Old 09-26-2008, 05:30 PM
Wow that is news to me about flashing pre dbw engines. I'd like to hear more about how thats possible.
Old 09-26-2008, 05:37 PM
ryanylva's Avatar
Did you look on their web page? They have a news feed on it.
Old 09-26-2008, 05:40 PM
ryanylva's Avatar
I'm ordering the h&r/bilstein sport package I decided. Will drop me 1.5" and handle alot better they say.
Old 09-26-2008, 05:42 PM
I guess they finally cracked the code that made the use of physical chip necessary. Impressive.
Quick Reply: Just got GIAC flashed!+++
