just fitted a r.tec mbc
Old 09-11-2010 | 11:58 AM
mathaste's Avatar
Default just fitted a r.tec mbc
ive attached one end to wastegate and other end to n75 valve and when i put my foot down it seems to cut out at about just over 0-5 bar any help would be apreciated cheers
Old 09-11-2010 | 08:05 PM
SVT_BRYAN's Avatar
Take the MBC out and just let the N75 do it's job.
Old 09-11-2010 | 10:31 PM
joenelson7687's Avatar
Check a couple things. First, check to see if the MBC is facing the right direction. Second, Check to see if you are in limp mode. You shouldn't be running only a MBC. You need to have a chip or the diode mod. What do you have? What year is your car?
Old 09-12-2010 | 04:28 AM
mathaste's Avatar
its a 97 model 1.8t no other mods apart from remus exhaust. whats the diode mod?
Old 09-12-2010 | 09:58 AM
CCA4's Avatar
The diode mod uses a 4.3v zener diode to trick your MAP sensor and let you run more than 9psi as controlled by a MBC. It's also irrelevant because the 97 isn't DBW and doesn't have a MAP sensor. The reason Bryan recommended you remove the MBC and just let the N75 do its job is that cranking the boost up with a MBC is a good way to fry your turbo REAL quick.
Old 09-12-2010 | 01:49 PM
mathaste's Avatar
i think a chip is the next step then
Old 09-12-2010 | 03:56 PM
CCA4's Avatar
When used in conjunction with a chip, a MBC *used responsibly* can be ok. If you slap one on and crank it up to 25psi you're going to spend most of your time in limp mode and fry your turbo
Old 09-13-2010 | 01:22 AM
Yep...so get a chip and leave the mbc alone....youll be doin just fine with a chip. Oh yeah, make sure you get a new diverter valve and a boost gauge!
twinblowersonice
09-18-2006 03:39 AM
donnaa5dcp
07-28-2006 09:31 PM
soupie69uk
05-04-2005 07:17 PM
millsi
03-08-2005 02:07 AM
Quick Reply: just fitted a r.tec mbc
