Intermittent electrical problem where ALL lights go black while driving?
Hi, new member here but long time reader so just want to say thanks in advance for any replies.
I have a 1999.5 mid-facelift Avant 2.8L v6 and I have had a problem of blinkers intermittently not working and sometimes the hazard lights coming on while the car is parked and off. I know I have to fix the hazard light switch in order to fix this problem and will be doing it this week.
Last week when I was driving at night my lights, I mean all my lights including interior gauge lights went off for a split second or so, happened twice. Yesterday when I was driving at night the lights went very dim almost black for a half second.
So while reading I found that this may be cause by the headlight switch and I have to remove the steering wheel to replace, which is no problem for me. My only concern was that ALL the lights went out when I was driving but power to the car remained constant. I noticed in similar threads it was just maybe the low beams or running lights.
I just want to make sure this may not be something like the battery or alternator or something else before I start digging into the steering wheel.
FYI I did do a mid to new facelift mod so I can have the double din console installed myself. So now I have a aftermarket Nav system installed.
It could also be the ignition switch flaking out. On my pre-facelift 99, the dash gauges are always lit, regardless of the headlight switch position. If it happened in my car I would start with the ignition switch, as that's what turns on the gauge lighting. If your car's cluster is always lit, regardless of whether your parking or headlights are on, I would suspect the ignition switch first. If your dash lights only come on when the headlight switch is turned on, then the headlight switch is probably more likely.
I already ordered a new hazard switch and will be ordering a headlight switch so I am hoping this will resolve the issue and I will report back.
jpcallmotor
07-14-2010 10:00 AM
