Interior lights not switching off when locked
It has worked before.. but from yesterday and onwards, it does not turn off when I lock it.
When it's locked, and I try to lock it again, the fuel filler lock bolt engine starts running, while the other locking motors do nothing.
I've tried spraying some anti-corrosive solvant in there, and pulling it a bit in and out, nothing works.
The lock bolt comes out just fine, and it retracts just fine. It has a little bit of slack, but only a couple of millimeters.
Can someone check if the lockbolt engine is running when you try to lock when car is already locked?
Yesterday, I did three things. I washed it (also inside the fuel filler cap area). I forgot to close the lid, so I drove with the lid open for about 2km to the store.. Maybe some dirt got in there somehow, since it was open.. But concidering the lid is blocking the air, it couldn't have been much..
Also I swapped stereo, but that was just a standard ISO-plug swap.
Help!
Help!
You mean turned the lights in the "on" position, to the right? Nope, they're set correctly to left position. I hope the fix is easy, but I guess just not THAT easy
I misunderstood how the lock system works, it's one single vacuum and pressure pump that is located around the fuel tank which controls all the locks.. didn't know that. So I hear the pump for the whole system. I still need to find out of the buzzing sound of the locking pump is to be heard if you try to lock a car that is already locked?
Also, how does the interior light autoshutoff work?
When I lock it, it starts to fade a tiny bit, then it pops back on. Seems like a classic stuck switch example?
hoovdiddy
07-05-2017 10:19 AM
Arnold K.
12-26-2013 10:49 AM
mrosebro
09-23-2012 12:28 PM
mack010s4
11-30-2010 10:07 PM
