intercooler core quality, size and myths
RE: godspeed core quality vs racetec
ORIGINAL: Matt_Iliketurbopull
is the garrett bar and plate? - YES!!! My favorite
where is the precision core, is it a kit?
yes that is also a very good core. and 034 sells that piping, it'll definitely hold up to the power
i dont think they make a kit to fit the b5 a4's so you'll have to get piping seperate
The godspeed is a very low dense core where the garrett/precision (they both use garrett cores) are very high dense cores. The precison 350hp core will work for you. Its about $300 and will keep the temps a few deg above abient as were the godspeed core will keep it probably closer to 20-30* higher, depending on size.
#18
thank you,
I'll probly get this http://forums.motivemag.com/zerothread?id=3551132so don't have to think about custom piping, hacking the bumper should be enough pain. Plus the moulded hoses look very cool-OEM like.
#20
i have the exact same core as the one that 034 is selling. it is leaps and bounds above the AWE core as far as reducing and pretty much eliminating heat soak. i am very happy with it. it fits nicely under my stock B6 bumper(although my rebar installed. so you'll have to trim that up if you keep it on your car).
