Installing aftermarket tach
1997 A4 2.8 quattro 5 speed 245k
Hi, new to the forum.
I searched for a tachometer install and could not find one. The tach on my dash only works when it wants to. The speedometer also does not work when tach doesn't. I use a GPS to tell me my speed when they aren't working. The tach will help in my downshifts. I have all ready mounted it on the dash. Looks real good, I just need to know where I can get the tach signal from? Any help will be greatly appreciated.
Thanks in advance.
Thanks in advance.
Wow, a after market tach? Please just fix the stock one, and ummmmm not trying to be a dick but my audi does the same thing and i can "downshift" perfectly fine. Once again please fix the problem and dont get a aftermarket tach! This is the audiforums not hondatech.
why do some of you guys act as if the car belongs to you?,just because he is registered on audiforums.com,doesn't mean he has to conform to what you think his A4 B5 should look like.
I've gotten the same thing from a member on this site,simply because i have Angel eyes lights on my B5.
The way i see it,everyone has their own individual style,likes and dislikes on what goes on their B5.
There is one B5 owner that has a chalk board hood on his B5,nobody said anything to him,i personally don't care for it but that doesn't give me the right to post about the fact i don't like it and why it should'nt be done to a B5,its none of my bussiness what he does to his car,just like its none of yours,what the OP does with his car.
anyone know where to get tach signal
quote from s2_Audi "Wow, a after market tach? Please just fix the stock one, and ummmmm not trying to be a dick but my audi does the same thing and i can "downshift" perfectly fine. Once again please fix the problem and dont get a aftermarket tach! This is the audiforums not hondatech. "
The car is my room mates. I don't drive it all that often, so I am not used to it. He does what he wants to it. Just trying to help out.
Quote from hiwords "you need to find out the root cause. it could be a sensor"
How can I go about doing that? Do I have to use a VAGCOM? What would make the stock one only work sometimes? Any help would be greatly appreciated.
Thanks in advance
Thanks in advance
I would start off seeing if your tach wire is getting a good signal. On your car it should be a green wire on the cluster plug nearest the door.
NOt sure what everyone has against aftermarket tach's, it isn't like all of them are 5" and have to be mounted to the top of the dash board. lol
Here is the one I have in my car, its actually needed seeing that my engine makes so much power it can out rev the stock tach.
