Idle problems
Old 12-16-2010, 12:09 AM
twaker2's Avatar
twoeightquattro, I think what you may be referring to is the purge valve, which should be making a ticking noise. Also, as Dragonrage was saying, the SAI pump is underneath the entire air box, and is hard to see/feel without coming up from underneath the car.
Old 12-18-2010, 03:35 PM
twoeightquattro's Avatar
thanks for the input, i will be checking the Vac lines real soon.
Old 12-18-2010, 04:46 PM
ptowna4's Avatar
Does anything happen when you put gas in your car? When you are close to empty and you put gas in does your car have a hard time starting?
Old 12-19-2010, 12:09 PM
willie7182's Avatar
twaker2 is correct. That is the Evap Purge Valve. It directs fumes from the fuel tank into the engine. Erratic idle can be tied to this valve, but in most cases it's something else. You can check it with Vag com. If your car has a hard time starting only after fill-up, it's usually a telltale sign that your Evap Purge Valve isn't working properly.
Have you cleaned your Throttle Body and done a good TBA?
audia4man
04-23-2013 05:46 PM
c346123
04-13-2007 04:04 PM
robjay31
09-19-2006 05:09 PM
96A4QuattroGuy
09-17-2006 07:17 PM
tank8970
09-11-2006 05:12 AM
Quick Reply: Idle problems
