Idle Issues
Old 04-21-2011 | 11:02 AM
browny355's Avatar
Default Idle Issues
So I'm trying to diagnose my idle issues before I dump even more money into trying to solve the problem.
The car idles low enough to make a loud knocking when idling, I presume it's the valves. If the car is in neutral the idle is high enough to sound fine. If I move the steering wheel, the idle drops and I hear the knocking. It also happens when in gear.
I believe I have replaced any possible vacuum leaks and there are no codes. Once in a blue moon the RPMs will jump around at idle and the car will not go. I just turn it off and restart it and it runs. Anyone have a clue as to what this could be?
I seem to have low/no boost so I'm thinking about replacing the DV. Could this be my issue?
Old 04-21-2011 | 11:27 AM
krazzz's Avatar
How many RPM is it running at idle? I'm guessing you have a 1.8/automatic?
Old 04-22-2011 | 09:40 AM
browny355's Avatar
Car idles at 800 RPM and is automatic. 50 RPM higher makes the engine sound fine. 1.8t AEB
Old 04-22-2011 | 10:01 AM
chocalotstarfish's Avatar
Super Moderator
Are you saying there's no codes cuz you pulled them or just cuz no CEL? You can have codes and no CEL.
Old 04-22-2011 | 10:17 AM
browny355's Avatar
No CEL, I'll try to pull codes today and give updates. Thanks!
I also bought a cheap ebay vag com connector off ebay. Should I learn to use this to try and diagnose the prob?
Old 04-22-2011 | 10:24 AM
Super Moderator
Is it a knock or a tic? Low oil can some times make the valves tic but definitely check for codes.
Entyqua
05-26-2010 01:07 PM
Migzy
04-21-2010 07:44 PM
shnebin
02-23-2009 04:07 AM
blacka6
07-26-2005 03:46 AM
acvega
03-08-2005 03:06 PM
