IAT sensor bad, where the @#$#@$ is it???
Old 03-28-2008, 04:26 PM
Default RE: IAT sensor bad, where the @#$#@$ is it???
[IMG]local://upfiles/12092/AB4FFB8BD9C24421973E36E3D08DC922.jpg[/IMG]
Old 03-28-2008, 04:34 PM
TheBat's Avatar
Darn it! Well thanks, but that brings me back to square one with the original problem up at post 9....
Old 03-29-2008, 04:14 PM
hb972.8q's Avatar
do you have the dtc codes or the p-code. i could give a good answer if i did.
there are like 15 dif codes for an bank 102 sensor
abs is only for the break system nothing to do with the engine?
confused
Old 03-29-2008, 04:33 PM
TheBat's Avatar
Well I put everything back together, fixed a broken vacuum line, and the car was running fine. Also cleaned the throttle body a little. I checked the codes again and there wasnt a code for the O2 anymore. I got a misfire for cyl 2 and 3. I had a misfire for 1 and 3 before, replaced the ICM, then got the O2 code. I cleared the codes and havent gotten any yet for about 8 miles.
What's the engine have to do with abs? I have no idea, but the code for that was rough road/engine torque. Whatever the hell that means. A tech said it could be the IAT. Thats ruled out, so I need to hook up the vag and clear the abs too. Using a desktop, pita. I'll post again if something comes up. Thanks for the help!!
neomaxddr
04-01-2009 03:16 AM
Quick Reply: IAT sensor bad, where the @#$#@$ is it???
