IAT sensor bad, where the @#$#@$ is it???
Old 03-26-2008, 07:18 PM
TheBat's Avatar
Default IAT sensor bad, where the @#$#@$ is it???
1997 2.8
I searched and found "its on your throttle body" or "its on the intake manifold after your throttle body", so I pulled my intake off and looked and looked but couldnt find ****! Where the hell is this thing! Is it underneath? Do I have to take the throttle body off? wtf.
Old 03-27-2008, 01:40 AM
TheBat's Avatar
Default RE: IAT sensor bad, where the @#$#@$ is it???
ttt
Old 03-27-2008, 03:16 PM
hb972.8q's Avatar
http://audi.kris-hansen.com/icv.htm
Old 03-27-2008, 04:13 PM
TheBat's Avatar
Well thats the Idle control valve, not the IAT. In his other tech articles he points out the IAT on the back of the intake tube, but where his is, I have nothing.
Old 03-27-2008, 04:31 PM
cincyTT's Avatar
I'm make believe
#9 just before the TB
Old 03-27-2008, 04:34 PM
Leifer's Avatar
It's tucked behind the throttle body, you need to loosen a screw from the throttle body to get to it.
Edit: By Nate's pic/definition (which was very precise ) I might have the wrong part.
Old 03-27-2008, 05:15 PM
TheBat's Avatar
Darn it, I don't have anything there. Here's a pic.
http://s266.photobucket.com/albums/i...t=IMGA0823.jpg
Are the 97s different maybe? I'm extremely confused here. I greatly appreciate the help and effort guys.
Old 03-28-2008, 03:51 PM
hb972.8q's Avatar
what code # do have the 12v doesn't have aiat
Old 03-28-2008, 04:05 PM
TheBat's Avatar
I have a code for the bank 1 O2 sensor. Also an abs code for rough road/engine torque. I was told the abs was from a bad IAT sesnor. I figured the O2 code was also a result of a bad IAT.
If the 12v doesnt have an IAT, that would explain a lot.
Old 03-28-2008, 04:18 PM
the 1997 dosnt have an IAT it has an IAC (idle air control valve )
Quick Reply: IAT sensor bad, where the @#$#@$ is it???
