I need some help???
ok there is alot of stuff to check on my car with this code but i wanna know if there is any specific part where i should start or if this is real common on this car where is usually the same thing causing the problem help please??
First check the all your vac lines for leaks, next remove and clean the maf sensor and have someone with a scanner, preferably vagcom check the values of your fuel trim and o2 sensor(bank 2)....id go with a vacuum leak somewhere
97 1.8t does not have a secondary air pump in it.
http://wiki.ross-tech.com/index.php/17544/P1136/004406
Possible Solutions
Check Mass Air Flow (MAF) Sensor
Check Fuel Pressure Regulator
Check Fuel Pump
Check Intake/Exhaust System for Leaks
Check Vacuum Lines for Leaks
Possible Solutions
Check Fuel Pump
