I need some help???
Old 10-26-2009, 04:16 PM
peterbr17's Avatar
Default I need some help???
I have an audi a4 1997 1.8t fwd and the check engine light is on and this is the code it gave me p1136? Does anyone know what this code means?
Old 10-26-2009, 04:31 PM
peterbr17's Avatar
ok there is alot of stuff to check on my car with this code but i wanna know if there is any specific part where i should start or if this is real common on this car where is usually the same thing causing the problem help please??
Old 10-26-2009, 05:06 PM
kbrookst's Avatar
First check the all your vac lines for leaks, next remove and clean the maf sensor and have someone with a scanner, preferably vagcom check the values of your fuel trim and o2 sensor(bank 2)....id go with a vacuum leak somewhere
Old 10-26-2009, 05:08 PM
kbrookst's Avatar
oh and the code is a system too lean fault.
Old 10-26-2009, 09:14 PM
Midniteoyl's Avatar
P1136 - Fuel Trim: Bank 1 (Add): System too Lean
Agree with kbrookst, check for vaccum leaks.. also check out your Secondary Air pump and hoses.
Old 10-26-2009, 09:48 PM
TeeterTawter's Avatar
97 1.8t does not have a secondary air pump in it.
http://wiki.ross-tech.com/index.php/17544/P1136/004406
Possible Solutions
Check Mass Air Flow (MAF) Sensor
Check Fuel Pressure Regulator
Check Fuel Pump
Check Intake/Exhaust System for Leaks
Check Vacuum Lines for Leaks
Old 10-26-2009, 10:07 PM
Midniteoyl's Avatar
Oops.. '97
Old 10-26-2009, 11:05 PM
peterbr17's Avatar
I was checking out if the vac had any leaks and this is what i found does anyone know the name of that piece look at the red arrows you think this has anything to do with it
peterbr17's Avatar
That piece is cracked in half
Old 10-26-2009, 11:33 PM
peterbr17's Avatar
Ok guys where is the maf sensor located and the secondary air pump?
