Hummng at high speed, but not when turning right
I have a 98 2.8q manual with 103k miles which makes a loud humming noise at about 60mph, but when I make right turns the noise goes away completely. It's not based on engine speed, so my first guesses would be:
1. tires (uneven wear)
2. wheel bearing(s)
3. something with the differential
Can anyone shed some light on what this may be? thanks!
2. wheel bearing(s)
couple of tips. you need a press to replace the wheel bearing. don't take the ABS sensor out of the hub. disconnect it from under the rear seats and keep the sensor on the hub. if you take the sensor out, you'll most likely destroy it and you'll need a new one.
