humming noise...someone help!
Old 12-08-2007 | 01:04 AM
stilldubbin203's Avatar
Default humming noise...someone help!
ok so what happened was i was going around a corner (only doing maybe 15mph) and i hit a patch of ice and hit the curb with my rear drivers side wheel, by the way its a 99 a4 1.8tq... i took a look at it and couldnt notice much damage except for the wheel being curbed....now when driving i hear a humming noise coming from that area and it gets louder as i turn right, mostly at a decent speed going arount right hand bends. The alignment seems to be fine but i do notice that the steering seems to be a little bit tighter when i turn the steering wheel left. could this be a bent tie rod, control arm etc.. or am i maybe in for something much bigger.
Old 12-08-2007 | 01:34 AM
Audi_Skydiver's Avatar
Default RE: humming noise...someone help!
Wheel bearing most likely.
Josh
Jack up the car so that wheel is off the ground and see if there is any play in it. If there is, look and see where it is coming from if you can.
Josh
Old 12-08-2007 | 01:36 AM
yea i thought the wheel bearing myself....in the morning ill jack it up and take a look
Old 01-02-2008 | 12:49 AM
SeaWolfxix's Avatar
Did you ever find out what the problem was? I hit a curb and have the same humming noise, especially when turning right.
Old 01-02-2008 | 01:07 AM
hiwords's Avatar
i missed this thread but the rear wheel does not have a tie rod lol. doubt it's the wheel bearing though.
Old 01-02-2008 | 10:23 AM
redsox12's Avatar
I diddnt hit a curb, but from a dead stop when I make a full turn I hear a low rubbing/humming noise coming from the front of the car. Could there be something wrong with the Q system?
Sheasta
04-12-2012 07:58 PM
Schlampah
01-27-2011 09:24 PM
lenny123
01-16-2009 03:33 PM
frankinstyn
02-29-2008 08:13 AM
hyperlight900
11-30-2007 06:37 PM
