Humming noise
Old 04-12-2012 | 04:23 PM
Sheasta's Avatar
Default Humming noise
Cant hear it all normal driving. Hear it while taking right turns at a pretty good speed only. Wheel bearing? Ideas?
Old 04-12-2012 | 04:33 PM
redmond1501's Avatar
Possibly driver-side rear wheel bearing. Is it coming from the back?
Old 04-12-2012 | 06:15 PM
morpheous's Avatar
I agree,wheel bearing. I just got both my rear wheel,bearings replaced. No more loud cabin noise. I can actually hear the other person on my iPhone,while driving Audina!
Old 04-12-2012 | 06:16 PM
Sheasta's Avatar
I think its coming from the front ill look into it more tomorrow. However it was sitting for a while before i bought it so pads and rotors were startin to rust even tho it had recent beake job. Could it possibly be that?
Old 04-12-2012 | 06:48 PM
morpheous's Avatar
Of corse its possible,maybe the pads were not seated properly,rotors are warped. ect...
Check the brake job over.
Old 04-12-2012 | 07:58 PM
jeckel20003's Avatar
Could be a wheel bearing. Could be a CV axle. Could be brakes. Could be a number of things. Which side is it coming from? Does it stop if you push the brake pedal? I recently had a noise at the front left wheel. My rotors were original. Weren't warped but they had worn down and rusted to the point that a flake of rust was hitting the pads and causing a noise. The noise would change if I was going straight or turning. Replaced my rotors and the noise is gone. If it is a wheel bearing, the noise will get more frequent and worse with time.
Schlampah
01-27-2011 09:24 PM
lenny123
01-16-2009 03:33 PM
frankinstyn
02-29-2008 08:13 AM
stilldubbin203
01-02-2008 10:23 AM
hyperlight900
11-30-2007 06:37 PM
