how to run led without headlights on?
ok so now they came in... aaand... the LED dont turn on.. it came with the round 5 pin connector which is what i have and i plugged it in... on audizine they say its supposed to replace the fogs but even when i turn the fogs on it doesnt turn on... and the blinker connector is only a 2 slot connection where as the factory is the 3 slot... does anyone know of a legit diy to get this working?? wtf
Figured out which wire served which function on the turn signals (one is for the turn signal, one is for the corner marker, and one is ground). Spliced into those wires with new wires (I used 14ga. wire) and put connectors on those. Then I found which wire powered up the LEDs, cut the end of it from the round connector, and put a matching connector on there to mate it to one of the new connectors. Your new turn signal bulb will require a ground wire and a power wire, so the other 2 new wires with connectors on them will be wired to the turn signal.
ok i did soemthing similar... i ended up taking some 12ga wire and grabbed some female and male butt connectors and connected the 2 new connectors (ground and blinker) into the original connection which left me with one extra slot... so i then spliced into the hot wire of the LED and ran it into the 3rd slot in the original connector which ran the park lights... i only did it on the passenger side, and the wires bridged to the other lights automatically, after about 5 seconds of running them in park mode (only led on) the lil mini 5a fuse blew... surprise surprise... so i just replaced it with a 15a mini fuse and its held up fine...
thanks again for helping
#19
BTW, for anyone wondering, it took a lot of research, but these or the tail lights he is running in the video, I purchased them two months ago and they look freaking fantastic. If you upgrade your 3rd break light and the license plate to white LED's it really updates the rear of the vehicle at night and makes it look like a much newer vehicle. Day time, heh very bright, but the full updated effect isn't as powerful in my mind.
EuropeanPerformanceProducts - LED Rckleuchten red/smoke fr Audi A4 B5 Lim. (Nicht S4,TDI) AZAL02RB
They are completely different and FULL LED compared to many of the shitty knock off on ebay.
PSULion21
03-18-2012 11:28 PM
ashulga
05-07-2010 03:40 PM
A62dot7turbo
06-27-2009 10:17 AM
mschwister12
02-04-2008 11:40 PM
