How to remove mbc
Old 08-11-2010, 06:41 PM
rb20cory's Avatar
Default How to remove mbc
can anyone tell me how to remove the manual boost controller
i have two lines connect it to mbc
one its coming from wastegate aND THE OTHER ONE FROM THE TURBO
IF I REMOVED THIS LINES WHERE DO I CONNECT THEM
thanks
Old 08-11-2010, 06:46 PM
turbo kraut's Avatar
Tech Guru
to your n75..... it is probably just plugged to the tip, and plugged in electronically
Old 08-11-2010, 06:48 PM
TeeterTawter's Avatar
to the N75 valve. http://www.google.ca/imgres?imgurl=h...1t:429,r:3,s:0
why are you removing your mbc?
Old 08-11-2010, 06:53 PM
rb20cory's Avatar
cause i think its not working right or maybe .sometimes it reads 0.6 or 0.7 i thought the last owner put backwards and and i switched the lines and no difference
Old 08-11-2010, 06:55 PM
rb20cory's Avatar
sorry i dont understand the diagram i have one line coming from the wastegate and one from turbo last time i put this together and no boost at all
Old 08-11-2010, 06:56 PM
rb20cory's Avatar
sorry but am new to audis
Old 08-11-2010, 06:59 PM
rb20cory's Avatar
also when i keep boosting the car starts smoking if i doost as much it wont smoke,thge last owner told me he had replace a put a new turbo a month a go this doesnt look like a new turbo...i did a compression test and came up 170 to 160 the lowest
Old 08-11-2010, 11:01 PM
joenelson7687's Avatar
Check to see if your wastegate is functioning properly too. If your wastegate is messed up, it won't matter how much boost you are requesting because the wastegate is going to just release it
Old 08-12-2010, 12:10 AM
rb20cory's Avatar
if i disconnect the line from wastegate when the car its on the idle wont change and theres no vacuum or anything like its dead ,is this normal
Old 08-12-2010, 12:35 AM
rb20cory's Avatar
i think my boost controller its install wrong cause the vacuums go directy to mbc and i dont c no n75
Quick Reply: How to remove mbc
