How to remove CD changer from trunk?
Old 01-29-2011 | 03:53 PM
Shadowlink's Avatar
Default How to remove CD changer from trunk?
I bought the Precision Interface Electronics Auxiliary input for the Audi A4 which requires you to plug in the 13 pin connection to the cable that goes into the CD changer thus rendering your CD useless after you do that. The issue I am having is figuring out how to remove that CD Changer to get to that cable. Would anyone be able to instruct me on what I need to do to access this?
Thanks
Old 01-29-2011 | 04:35 PM
Skythe's Avatar
Are you talking about the CD changer connection in the factory headunit itself, or a connector at the CD changer in the trunk?
Old 01-29-2011 | 05:03 PM
Shadowlink's Avatar
The one in the trunk. Thats the cable I need to unplug and plug into the auxiliary unit and then run an RCA cable from there to the front seats.
Old 01-29-2011 | 07:56 PM
460Jetboat's Avatar
there are two screws, one on each end of the CD Changer. You will need a stubby phillips. Why not just pull the radio and plug in behind there, instead of running wiring all the way from the trunk to the front seats? That's where the cable originates.
Gecko Asiks
02-26-2018 11:13 AM
TTismagic
02-04-2015 11:28 AM
Paul1234
01-03-2013 10:02 AM
XPTO2511
08-01-2009 07:55 PM
Hecareth
03-06-2005 09:57 PM
Quick Reply: How to remove CD changer from trunk?
