How much load is enough?
I've been studying control arm DIY's and I'm going to be buying the FCP Groton control arm kit this summer.
In the DIY's they talk about having to have the suspension under load when tightening the bolts on the control arms.
How much load is enough? Is it acceptable to use a floor jack under the ball joint and just jack it up a few inches?
please help!!!
first off im getting 2 codes
17965 charge pressure control
engine mount solnoid [not sure of code,will know 2moro]
my car is an 01 A4 1.9tdi[red I] 130bhp SE and has always had serious power,the turbo always kicked in the minute i pressed the accelerator,,but since i had the fault codes,the turbo doesnt kick in till 2500-3000 RPM,,an when i get to 60 or 70 MPH the car just loses all power an goes into LIMP MODE,
anyway
[pls bear with me this is my 1st post an just trying to explain the best i can]
my m8 has a 02 1.9 tdi[normal I] so i swaped sensors with him an it turned out that,,
it was the TURBO BOOST sensor,,now the turbo kicks in at 1500RPMs an doesnt go into LIMP MODE,so i taught i had it fixed but now my problem is,,
its no where near as fast,,the turbo kicks in right and no limp mode,,
but it just feels like there not enough turbo or im after losing horse power????
does anyone have any ideas?? i would be really grateful if there is any
maybe change the N75 valve????
these forums have been unbelieveable help with everything,,but this one is just really getting to me,,,
any replys wud be helpful
thank you very much
gerry
sorry if i have this in the wrong forum dont really now which 1 to put it in
thanks again
anyway
thank you very much
gerry
thanks again
