How much to fix sunroof?
Can you describe the symptoms? The switch and the rails that the glass slides on are both common points of failure for the sunroof. Neither will be cheap to fix if you take it to a dealer or indie shop, but both are fairly easy fixes if you're handy with a wrench
You shouldnt need it to be open to get to the contacts. There is a DIY around here that shows how to remove the switch itself, disassemble it, clean the contacts, and re-assemble.
Edit* http://www.a4mods.com/index.php?page...s/sunroof.html
mrocke440
11-20-2010 09:11 PM
tariqahmad
10-16-2009 11:49 AM
