How much am I dropped???
I think I need to clean one of the springs the next time I lift the car to see if I see any writing. I need to take some pics of my car so you can see how low it looks on a flat street, because I had the tripod pretty low too. I actually have barely a 3 finger gap and the tires are 205/55/16. I'd be surprised if this is only a .5'' drop.
this is my car, its a non sport. suspension is 100% stock. so your car should be lower than this by a little if you are sport. my tires are 205/60/R15
and a 3 finger gap is pretty low, i can stick my arm in my wheel well and move it around with plenty of room
i need to go lower badly
O.k., thank you Jc61990. I'm anxious to figure out what the hell my springs are then. Lets just say that these can't be sport springs, unless they're cut, because I have to drive up two pieces of wood in order to fit the floor jack under the front lifting cups. I won't be able to figure it out 'til my next oil change, because that's the only time my car gets in the garage.
**UPDATE!!**
I finally found a little spot through the gap above the back tire that had had some writing on the spring. I poked through a little flashlight that I had and low and behold they are EIBACH. They are black so it has to be the pro-kit (1.2''f/1.2''r). Well, now I need to look for some new shocks then since these seem to be pretty much shot. Thanks for posting up pics everyone.
