How long can I run without my MAF sensor?
Old 04-02-2008 | 03:54 PM
thndrlight's Avatar
Default How long can I run without my MAF sensor?
My MAF sensor is bad, I tried cleaning it, and replacing the filter, still ran bad. Disconnected the MAF sensor and it runs like a champ. Was curious how much damage can be done running without it for a while. I have to order the part and I need to go out and work on Friday. Any help is deeply appreciated. Thanks
Old 04-02-2008 | 04:07 PM
Jeff's Avatar
Zombie Defense Force
Default RE: How long can I run without my MAF sensor?
what year is your car?
cincyTT's Avatar
I'm make believe
Gas milage is a little worse, but you are fine without it on a 2000+ car. I ran mine for like 3 months w/o the maf to find out it was a loose connection on the turbo and not the maf.
Old 04-02-2008 | 04:18 PM
thndrlight's Avatar
My car is a 99.5 1.8T quattro.
Old 04-02-2008 | 04:21 PM
Leifer's Avatar
Dear lord Nate, your avatar.... [sm=wtf.gif]
To keep things relevant, I actually ran without a MAF for a couple of hours, it worked out fine. Just don't delete it; replacing it asap is probably best.
Old 04-02-2008 | 04:25 PM
cincyTT's Avatar
I'm make believe
^ you have a map. he doesnt. The base maps (not sensor) will be fine, but just not work as well ona AEB car like the OP has.
Oh, and get off my fat pig!
Old 04-02-2008 | 05:03 PM
A4speed's Avatar
haha, do u make those on paint or something?
Old 04-02-2008 | 05:05 PM
thndrlight's Avatar
So I'm good to run with it disconnected for a few days then, and it won't hurt anything?
Old 04-02-2008 | 05:07 PM
A4speed's Avatar
your engine won't be top notch by any means, but you'll be ok without it for a short period of time. expect a CEL light for sure though
Old 04-02-2008 | 06:01 PM
cincyTT's Avatar
I'm make believe
Just dont go nuts on the car and you will be fine.
ORIGINAL: A4speed
no, i get them online and didnt like to original colors
boxsata
10-23-2006 01:41 PM
TomRitt
10-06-2005 11:57 PM
Quick Reply: How long can I run without my MAF sensor?
