How do you set up intake on B5??
Old 07-01-2009 | 04:36 PM
a4haze's Avatar
Default How do you set up intake on B5??
Hey,
im a new member.
I hqave a 1999 a4 1.8t. i want to install a short ram or a cold air intake on it but the inlet to the manifold is a weird shape. it is not the normal circle or oval. how will i be able to fit something on it. is there a way to retrofit it or maybe there is a adapter???
Thanks!!
Hass
Old 07-01-2009 | 05:04 PM
hiwords's Avatar
you do know the filter goes on the turbo since you have a turbo right?
Old 07-01-2009 | 05:10 PM
teamdaraptor's Avatar
I have a write up on here somewhere that pretty much showed you exactly how 2 do it with pictures as well. Search.
Old 07-02-2009 | 10:02 PM
a4haze's Avatar
whould a short ram intake be easier to use instead of a full set up???
And what do u mean the filter goes on the turbo???
Old 07-02-2009 | 10:14 PM
a4haze's Avatar
plesse let me know. thanks
Old 07-02-2009 | 10:15 PM
hiwords's Avatar
on a car with a turbo, the air is sucked into the turbo first and then through the throttle body instead of a NA car that sucks the air straight through the throttle body. so like i said you have to attach the air filter on the turbo. the airbox is already there so you'll have no trouble finding where the filter goes. you know you sound like you really don't know what you're doing, i'd get somebody who does and have them do it.
Old 07-03-2009 | 09:45 AM
yuriy's Avatar
IF you buy a short ram setup, thats usually how its gonna look. The metal pipe from the kit attaches onto the stock hose that connects the turbo with the air box.
Also, check this out. It shows you how to install a K&N intake kit. Its pretty similar for any kit and not that hard really.
David Narez
06-26-2013 09:20 AM
lukestaah
07-28-2012 11:26 AM
ryanjayblair
B7 Models
05-28-2009 05:13 PM
apg96
06-28-2005 05:34 AM
Quick Reply: How do you set up intake on B5??
