How do I undo this??
Hi,
My wife was driving to work this morning when our 2.6 B5 A4 started leaking coolant.
After swapping cars and topping the water up several times, I got the Audi home and have taken of the fuel rail, injection manifold, and have found the leak.
It's in the pipe that runs from the LHS of the radiator, around the back of the motor, splits into two and under the fuel injection to the front of the block.
These is a split in the Y join which shouldn't be too hard to have welded by a friend who is an expert welder.
However...I am having a real problem getting the heater coupling off this pipe.
It is a solid joiner with a spring clip.
I removed the spring clip, but I can't get any movement and as I don't want to break anything, I thought it better to ask for some help.
You can see the connection just below the red nut, how do I get this connection off???
Thanks in advance
Thanks in advance
As is the case with all of the coolant pipes on the B5, you're gonna have to pull. HARD. Once the spring clip is off, there's nothing but gunk holding those two pipes together. Make sure you pull straight. When you start twisting and turning stuff is when you're going to break something. Don't worry about pulling too hard, as long as you pull straight the pipes will come apart before you break anything.
