How to do HID
#21
I didn't say you DO have junk bulbs. I said maybe. Besides, bulbs lose brightness over time, especially bulbs that AREN'T 85122+ (the plus is important). The 85122+ - well, they're not perfect, but they lose less over time.
#22
well since you know about hid bulbs.... where can i get some for cheap?? i want some bright bulb or green.... i have an S4 bumper but i dont like the yellow foglights... what the best hid kit to get so it wouldnn't shine yellow?
#23
I don't know much about HID fog lights so I will not answer that one, other than saying you can probably find out about it at HIDplanet.
You can't get green capsules. But if you have D2s capsules then I recommend those 85122+ and I ordered mine from a site called "The Retrofit Source," but there might be cheaper sources. They are not cheap capsules, though, at around $100 for a pair. They are the brightest and longest lasting that I know of (3400 lumens). The Morimoto capsules they carry are supposedly pretty decent, too, but not as good as the OEM brands like Philips. Cheaper though. Will be a bit less bright and won't last as long.
#27
Before knocking DDM read;
http://forums.nasioc.com/forums/show....php?t=1888414
http://forums.nasioc.com/forums/show....php?t=1884084
On this forum many members used VVME in the past with good results.
#28
Look at the chromacity diagram I linked before. Green is not on the curve in that. The only way it can be done is with paint. And then it wouldn't have a K rating.
#29
Well, if rice is what you're going for.
