hopefully nothing major but.....
ok every other time or so when i turn my car on in the morning or when it is cold, it sounds like my splitter is blowing off at iddle? like i can hear a slight woosh....? i tried getting a sound clip but everytime i get the camera it wont do it...lol
my cars an 01' 1.8t 5 speed,
upgrades, sppedtuning chip, forge splitter dv, k&n filter, exhaust if that helps?
thanx, nd sorry if its a stupid question but it only started doing it recently....
you think it sounds like its the valve?
i had it running for a couple weeks now and it just started doing it like 3 days ago?
is it prolly cuz the speedtuning just got broken in? and its causind the turbo to spool up some more?
theres always a possibility.. i have my dv cranked down to where it will only go off at 15psi, and its been too cold for me to lower it. although it sounds really cool when i let off the throttle at 15 and hear it flutter
yea it does sound very cool...
but why would it do it at iddle? thats what i dont get, it shouldnt boost?
hmm i want to try and make it so that it recirculated all the pressure back in see if it helps my performance a lil bit better instead of blowing it off....do you need that plugg instead of the horn or do i just close it all the way?
Well the amount of air it is releasing could be negligible enough that the sensors aren't catching a problem. I'm thinking there may be something with your valve. Perhaps it just needs to be lubed a little bit, or the spring may have given out? Because even if I have mine set really soft, I don't get any "blow" while idling. So I would look into that... Otherwise, I don't know what it could be.
