help me please
Old 10-04-2008, 02:27 PM
kloepfer_3's Avatar
what does that tranny limp mode mean??
Old 10-04-2008, 02:42 PM
onepoint8tee's Avatar
It's just a fail safe mode if the TCU see's something wrong. You go as fast as 4th gear will take you without getting to high in the revs. You could cruise around 60mph comfortably in 4th. Its just the get up and go that you'll be missing from 1st-3rd.
Old 10-04-2008, 03:09 PM
kloepfer_3's Avatar
Thanks so much. Where is that located at? If u could est price on repair? To get the part I guess order from audi?
Old 10-04-2008, 03:23 PM
It's located on the tranny, its what detects which gear you are in. Don't know about a price, and I don't know if it's something I'd do myself or not. Send auditech79 a pm about it.
This doesnt really give much info, but I had this in my photobucket album:
Old 10-04-2008, 04:51 PM
kloepfer_3's Avatar
Dam I thought maybe it would be outside of the tranny. That means it will probally be a lot to fix def if they gotta drop the tranny. Sucks cuz I just got that car back.
Old 10-04-2008, 05:05 PM
sm8681's Avatar
It sounds to me like something is seriously wrong with your Transmission Control Module. If the red display unit on your dash that shows what gear your in (whether it be P, R, N, D, S or 1-7) begins to flash then your really in trouble. Your TCM communicates to your tranny when you put your car into gear and tells it which gear to go into. It is pretty much sounds like an electrical malfunction that your experiencing but the TCM is a major replacement. A commone sign of this is that your reverse lights will fail to come on when the car is supposed to be in reverse. Good luck.
Old 10-04-2008, 06:20 PM
kloepfer_3's Avatar
I'm so screwed. But I have no problems with reverse though. Its just when I put into drive.
  #18
Old 10-05-2008, 11:00 AM
kloepfer_3's Avatar
How long do you think I can drive the car?? I gotta get to work and there no other way to get there.
  #19
Old 10-05-2008, 12:08 PM
The range switch is outside of the tranny. It's actualy a pretty common fail, more so than the tcu. You can limp around in 4th for as long as you need to, but the sooner you get it diagnosed the better.
  #20
Old 10-05-2008, 12:26 PM
kloepfer_3's Avatar
So its outside the tranny so hopefully it won't be that much to fix wait its a audi haha.
