HELP! Flex hoses for Rear Right Caliper - Inner or outer?
One of my flex hoses is cracked and leaking brake fluid. I'm not sure if its the inner or outer flex hose. Tbh I'm not even sure if it has inner and outers. Its a 96 quattro. Anybody have a picture or part numbers or anything?
Thanks in advance,
G
Thanks in advance,
G
Seems the leak is coming from the caliper behind that bolt where the ebrake mechanism is. I'm gunna pull the caliper out and take a better look. The flex hose attached to the caliper is cracked too so I'll have to replace them anyways.
Bad bad news about the caliper. I had the same problem with both of my rear calipers, and I tried to rebuild one... Epic FAIL. Then, when doing some research, I found out if that particular seal goes bad, you need to replace the whole caliper. I think I paid about a hunder bucks each for remanufactured calipers at AutoZone, plus a core charge.
I suppose the JB Weld thing might work in theory as long as you don't use the e-brake. I wouldn't recommend it though.
Yes, the calipers can be rebuilt, except that seal... sorry to say, but you're SOL...
