help with this engine code?
i was in class the other day and we were using engine scanners and ofcourse they had a snap on ethos with a vagcom update so ii pluged it into my car and got this
P1545 Throttle Valve Controller Malfunction
any help with finding out what this means would rock, thanks guys.
Have you performed a throttle body adaptation? Clear the code and leave the key in the on position without starting the car for about 30 seconds, and then drive the car. Hopefully the code won't come back.
17953/P1545/005445 - Ross-Tech Wiki
Save the link, and anytime you need to look up another code, just enter it in the search box.
Here's a summary of what it says:
17953/P1545/005445 - Throttle Valve Controller: Malfunction
Possible Symptoms
Increased Idle Speed
Bucking at Load Change
Possible Causes
Throttle Body dirty
Throttle Body Wiring faulty
Throttle Body faulty
Possible Solutions
Clean Throttle Body
Check Throttle Body Wiring
Check Throttle Body
Special Notes Use Meas. Blocks & Basic Setting for testing
When found in the NAR 2.0l TFSI: (BPY, CCTA and CBFA) check TSB 01-09-04 or 2018652 for a wiring repair at the Throttle Body.
xristos.greece
08-13-2017 08:24 AM
